dcont Posted October 19, 2007 Share Posted October 19, 2007 (edited) Has anyone noticed that when stretching the length of a wall while holding the shift key doesn't always keep the angle of the wall constrained? Here's what I did. I selected the wall, clicked the endpoint and while holding the shift key, shortened the wall. I did this a few times to be sure that I am holding the shift key down when I lift the click to shorten the wall. Others in our office have noticed the same thing on other computers, all using VW2008. Is there something that I am missing. Edited October 19, 2007 by dcont Quote Link to comment
Guest Posted October 19, 2007 Share Posted October 19, 2007 Make sure you click before you let go of the Shift key. Quote Link to comment
dcont Posted October 19, 2007 Author Share Posted October 19, 2007 (edited) I have been. and I am doing it over and over the same exact way and it seems to be hit and miss. could this be a bug? Edited October 19, 2007 by dcont Quote Link to comment
Guest Posted October 19, 2007 Share Posted October 19, 2007 Do you have snap to grid enabled? Have you tried in a new, blank document or other documents? Quote Link to comment
dcont Posted October 19, 2007 Author Share Posted October 19, 2007 (edited) Grid snap is not enabled. I copied a couple walls from my file into a blank document and it still happened. Again, it is not a consistent thing. I tried it with a wall created from scratch, unstyled and it still did it. Edited October 19, 2007 by dcont Quote Link to comment
Guest Posted October 19, 2007 Share Posted October 19, 2007 Did you try a plain unstyled wall in a new, blank file? Does it happen with the line (or polygon) tool? Quote Link to comment
dcont Posted October 19, 2007 Author Share Posted October 19, 2007 My last post is showing an image of a new unstyled wall in a blank new document. It does happen on occasion with the line tool as well and with multiple different people in our office. Quote Link to comment
Graphite Studios Posted October 21, 2007 Share Posted October 21, 2007 Hello: This is very similar to the issues I have been having with constraining of walls, lines, etc. while drawing. The issue appears randomly (though consistently) for me as well in blank new files using unstyled walls, unmodified workspaces, etc. For myself, this is a fresh, new install of VW2008 on a new Mac without any plugins, etc. There seems to be no logic to the values of the 'constrained angles' walls/lines snap to. The tooltips that identity the 'shift-constrained' wall/line seem to have no relation to the coordinate system of the drawing or each other for that matter. For instance, the tooltips that read 'horizontal' and 'vertical' are definitely not perpendicular to each other or the orthogonal system of the model. The values, as dcont states, appear completely random. The databar seems to work fine only if I do not enter any values or if I do not try to constrain the wall/line I am drawing. Perhaps there is an obvious convention or setting I have overlooked, but something seems not quite right with the databar. Patrick Quote Link to comment
