Landmark Feature Survey
"10. Plant Database ? provide additional plant data and improve the interaction between VectorWorks and the plant database."
Questions like this do not encourage one to reply. I don't want any more North American (or even South American) plants, but would want the database we were promised.
Vehicle tracking/ turning circles would be good.
I use Landmark for Urban Design projects such as residential layouts. Testing these layouts (which may incorporate de-engineered roads) as to whether they work in terms of vehicle movement would be a real benefit. AutoCAD has an expensive bolt but there isn't one available for Vectorworks as far as I know.
Darick, thank you for asking! It would be wonderful if someone could link the two/three "databases" of plants; the Plant Reference Database, Object Info, and the Resource Browser plants (if that's what I'd call them) so that there was some consistency in the verbage, at least. On one there is an ID, the other has a CODE, neither of them work in the other. On one it's called "Name", on the other it's called "Plantlist Name". Plantlist Name is not the same as Plantlist Category, yet when you look at one, you get one label for it, and it's different in the other. The whole Plants part of this software is what I really wanted to use in-depth, yet it is so cumbersome to use, and almost impossible to try to figure out. I'm convinced that whoever designed the Plant Database portion, never consulted with the one who worked with the Res Brow or the Obj Info portions, nor proofed it after the design, with anyone who was going to use it.
