Graphite Studios Posted October 18, 2007 Share Posted October 18, 2007 Hello: This is probably a simple problem on my part, but I'd don't recall this being an issue with VW 2008 prior to the SP1 update. Previously, I have been able to draw walls using the 'shift' key to constrain the drawing of walls along the horizontal or vertical axis. This is still the case except when I enter a length for a new wall segment. Typically the active wall length is fine, but the next (and subsequent) wall lengths snap to odd angles when I use 'shift' to constrain for horizontal/vertical. The smartcursor tip reads as horizontal, vertical, etc. but the walls are definitely no longer correctly oriented relative to the other 'horizontal/vertical' geometry. This is confirmed by the databar angle field - such as a 'vertical wall' constraint snap at 97.15d. It is as if a new origin/axis point is created when I enter the length for the wall segment. I've attached some images to illustrate this issue. Perhaps there is a setting or other step I am missing? I am still learning my way around VW, but as I mentioned, I did not recall this being an issue prior to the 2008 SP1 update. Any help would be greatly appreciated. Thanks! Patrick Quote Link to comment
bohlr Posted October 19, 2007 Share Posted October 19, 2007 I am havingthe same issue Quote Link to comment
Petri Posted October 19, 2007 Share Posted October 19, 2007 This explains what I saw the other day! Quote Link to comment
Guest Posted October 22, 2007 Share Posted October 22, 2007 Are you guys working with a rotated plan view? Quote Link to comment
Graphite Studios Posted October 22, 2007 Author Share Posted October 22, 2007 Hi Katie: No rotated plan view here... occurs even in a blank, new file using unstyled walls, unmodified workspaces, etc. For myself, this is a fresh, new install of VW2008 (with SP1) on a new Mac without any plugins or other modifications. Patrick Quote Link to comment
Guest Posted October 22, 2007 Share Posted October 22, 2007 We're looking into this. Quote Link to comment
Graphite Studios Posted October 24, 2007 Author Share Posted October 24, 2007 Thanks for the update Katie. Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted October 25, 2007 Vectorworks, Inc Employee Share Posted October 25, 2007 (edited) There should be a fix in the next service pack for this issue. My apologies for the inconvenience. Edited October 25, 2007 by Andrew Bell@NNA Quote Link to comment
