Searchfield Posted May 11, 2000 Share Posted May 11, 2000 When I insert a Detail Bubble into a drawing I get no text ie record number in the bubble. The bubble has a solid fill but no text. I'm currently using version 8.0 Quote Link to comment
FRED JOHNSON Posted May 11, 2000 Share Posted May 11, 2000 I was having having the same problem then realized the bubble was being inserted on a layer set to "overlay" or transparent. When I changed the layer appearance to "paint" bubbles displayed correctly. HTH, fjjRA Quote Link to comment
Searchfield Posted May 12, 2000 Author Share Posted May 12, 2000 Thanks for your reply on the bubble problem. I have found that I can get text into the bubble by using checking the "link text to field" box in the Create Detail Bubble Symbol dialog box. I have check my setting and found I am in the paint mode. quote: Originally posted by FRED JOHNSON: I was having having the same problem then realized the bubble was being inserted on a layer set to "overlay" or transparent. When I changed the layer appearance to "paint" bubbles displayed correctly. HTH, fjjRA Quote Link to comment
