I just installed my update of VW 2008, hoping it might help the rather basic export/import problems reported before.
No joy - same bugs exactly. I submitted the bug again through bug report, but I'm not sure if that is a black hole.
This is a very basic problem. If I can't depend on the export or import of a simple polygon with 5 vertices (2 simple radius, 1 bezier, two end points) then certainly anything even slightly complicated would be suspect. In fact all you seem to need to have is a bezier vertex between two corner vertices to have a serious problem as in the enclosed file.
OOPS - I guess I can't enclose the file because 2008 file extensions (.vwx) aren't allowed on the forum!!!
jfitch
18 answers to this question
