Bill Hui Posted October 4, 2007 Share Posted October 4, 2007 I am new to Renderworks, do not know how to apply finishes for the VW 3d door & window plug-in wall symbol. Can anyone teach me how to do an alum door & window in a brick wall. THX. Bill Quote Link to comment
Bill Hui Posted October 11, 2011 Author Share Posted October 11, 2011 (edited) Can anybody tell me how to export VW2010 3D file to Cinema 4? Thank you. Edited October 11, 2011 by Bill Hui Quote Link to comment
bcd Posted October 16, 2011 Share Posted October 16, 2011 HI Bill Q1 - The Doors and window parts usually have classes attached. You can edit the textures applied to objects using these classes in the Tools>Organization>Classes dialogue box. Q2 - I don't believe the C4d integration began until VW2011 - try to export a 3ds file from VW 2010 and import that. Let us know how you get on. Quote Link to comment
Barbara R-N Posted October 23, 2011 Share Posted October 23, 2011 Hi - I am having trouble exporting my model in VW to the latest version of cinema 4d. My file exports as an empty file with zero kb. Any hints or suggestions of where to look for more info especially re: work flow? Still need to update my signature: VW 2012 + Renderworks Mac 10.6.8 Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted October 23, 2011 Vectorworks, Inc Employee Share Posted October 23, 2011 HI Barbara If you have Renderworks, you should be able to use the command File > Send to CINEMA 4D. This will open your file in CINEMA directly. Hope that helps. Quote Link to comment
Kevin McAllister Posted October 24, 2011 Share Posted October 24, 2011 Hi Barbara, Is an empty layer active in Vectorworks when you do your export? Both File>Send to Cinema 4D and File>Export>Export Cinema 4D command only export the current active layer. Kevin Quote Link to comment
Barbara R-N Posted October 24, 2011 Share Posted October 24, 2011 Thanks for all of the good suggestions - nothing has worked yet. I updated w/ SP1 and that took care of the frequent crashes. I'll reinstall VW and see if that doesn't help. Quote Link to comment
Barbara R-N Posted November 2, 2011 Share Posted November 2, 2011 Thought I'd post my solution, in case someone else had this problem: I had used a / in the name of one of my files, as in ...10/14.... Quote Link to comment
