cdavis
How do you get the Plant Tags to appear in the Default font
My Default font is Arial. The plant tags font appears in the font "Alba" and must be changed for any tag displayed. How do I set up another font as the default plant tag font.
Is this a converted file from VW 12 or a new file?
Are you pulling plants from a custom database you created, or from a library?
I assume you are referring to 2008. If not, please note the version of VW.
It may be a good idea to add a signature to your profile, including OS and VW spec info.
I've noticed that plant symbol tags display in different size fonts than the document setting, some are larger and some are smaller.
This happens if the symbol is dragged from the Resource Browser.
The font is the correct size if the plant tool is used.
The drop down list in the plant tool scrolls so slowly that I prefer to use the Resource Browser. It is also more graphic, allowing thumbnail display of the symbol.
Can the font size problem be solved with the Resource Browser?
