Dieter @ DWorks Posted September 28, 2007 Share Posted September 28, 2007 If I render with this mode, All 3D Polygons and NURBS do not show up. What do I need to do? Is this a bug? PS: This is in VW11.5 Quote Link to comment
islandmon Posted September 28, 2007 Share Posted September 28, 2007 v11.5 has a habit of totally hiding stuff... which then requires you to either goto PlanView or use the 3dRotate Tool to clear the VRAM buffer before the objects instantly re-appear on screen. Yes.. yes ... a bit peculiar and highly dependent on the video card & drivers... but a fact of life none the less... especially with complex data structures using thousands of Objects. Is this part of your problem ? Quote Link to comment
Dieter @ DWorks Posted September 28, 2007 Author Share Posted September 28, 2007 (edited) No, I recognise the problem you describe, and when you zoom in or out, all the objects show normal again. But this is different, 3D polys and nurbs just don't render in polygons with no shadow. I should clarify: They render with no edges. EDIT: they render in 'polygons final' But not in the other polygon render methods. Edited September 28, 2007 by DWorks Quote Link to comment
