Jeff Mac-User Posted April 20, 2000 Share Posted April 20, 2000 I have created and attached some records, I know how to create a report. Now I would like to extract data into a separate worksheet for calculating purposes. I tried the syntax mentioned on Pg 15-15 of VW manual with no success. Error message of "Invalid Factor" appears. I can't figure out the proper path name needed between the two worksheets. Any help appreciated. At some time I will be wanting to import/export between a VW database & an Excel spreadsheet. Any info on that procedure will also be appreciated. Thanks. Quote Link to comment
Guest Posted April 22, 2000 Share Posted April 22, 2000 We apologize for the lack of clarity in the manual. As with any calculation you must first enter a "=" sign before the formula listed. I.e. =(Worksheetname:cell/range address) This should work for you. If you are still having problems please contact Technical Support at (410)-290-5114 for further assistance. ------------------ Brian O Diehl Graphsoft, Inc. Technical Support Quote Link to comment
