JoeF Posted September 23, 2007 Share Posted September 23, 2007 I am trying to use a Drawing Label in a Viewport Annotation. Everything is going well till I set the bubble to sheet + item #. The label then justifies so the scale and view title are overlapping. Adjusting the text margin only works if I use an "item # only" bubble., When I have the bubble set to sheet + item the text margin does not work at all. Any tips? I would also like to set the Sheet label and scale to different fonts or at least bold and not bold. Is this possible? Quote Link to comment
