Center Line Tool
I've always made my own center line markers. I knew we had center markers in the Dim/Notes tools. So I just looked up in the help and it says the center line markers are in the Dim/Notes tools and there are 4 styles. I just looked for them and I don't have them. Do they exist? I opened the workspace editor and they're not in there. Is it a tool that use to be. Or do I not know where to find them.
The Center Line tool is only available in the Machine Design package. Unless you have Machine Design or Designer, you won't have it.
If you do have Designer, check under the Dims/Notes category, not the Dimensions category to add it to you workspace.
At least in VW12, it is a fairly primitive tool. You do have 4 options, but they are almost the same. Plan and italicized, either with the L passing through the C or starting in the middle of the C.
Pat
