nabw Posted September 13, 2007 Share Posted September 13, 2007 Does anyone know how to create Random paving. If you select the flagstone setting, it comes out wrong, as traditionally when laying a random patio you should not have more than 4 straight edges in a row. There are stone suppliers who offer there own patio generator on there but think I might be missing something in Vectorworks. Any help would greatly be appreciated...Thanks Quote Link to comment
dhbrown Posted September 14, 2007 Share Posted September 14, 2007 I agree, the one in the system is useless. I have spent a few days creating a random pattern for patios and I'm hoping we are going to save time with it. Here's how I did it. I actually created the cut sizes as they are purchased (in 2-D, not 3-D). On each, I added the "size" in a letter form that the stone vendor uses ie. 1'x1' = A. This is what the stone builders go by, letting them see when a piece is to be horizontal or vertical. Then I made it into a Symbol, with the actual size as the name ie. 1'x1'. I created a folder in the Res Brows called "Cut B/S" under Symbols/Plug-in Objects. I also made a legend to plop down onto the dwg, created it as a Symbol, and added it to this folder. This way I won't have to re-create the legend each time. All this work in creating the actual pieces is so I can then create a Hardscape worksheet, similar to a Plant List, and have it come up with a qty count, name, and size on the dwgs, which I can then also print out separately. After I created all of these pieces, I then painstakingly laid out these pieces in a random pattern, about 20'x30' in size so that all I need to do is copy it onto a new patio area we've designed, and then simply trim off the pieces I don't want. Having it this large allows me to pretty much cover the size patios we may do. I can also enlarge it. I will never have to lay out a pattern again, saving tons of time, as you know. I am literally working on this today, as a matter of fact. Hope this helps! Quote Link to comment
mike m oz Posted September 15, 2007 Share Posted September 15, 2007 Have you tried the Tile command (Modify menu). With a bit of effort you can probably create your own repeating pattern symbol to use as the tile Quote Link to comment
dhbrown Posted September 20, 2007 Share Posted September 20, 2007 Yes, I just tried this. It's no good for us because it doesn't seem to allow me to use text that I've embedded in my symbol. It also took a very long time to open. I'm finding that me individual pavers and the overall pattern I've creating is really slick! I love it! Thanks for "thinking outside the box"! Quote Link to comment
