Musical Symbols
deljones
  • 4 weeks later...
  • 11 years later...
  • 1 month later...
I see some new drum kit symbols were recently added to Service Select.
1972076966_ScreenShot2018-12-05at12_13_27AM.thumb.png.e267f89cc9c3e8211e549868e0870c6a.png
I apologize in advance for saying this, but did the person who made these ever see a real life drum kit? Did they not research drum kits? Not a single one of the three pictured symbols bears any resemblance to reality. (Not talking about level of detail, but literally just general proportions, placement, how stands work, etc). It's good to keep it simple, but it shouldn't be wrong.
I can accept the fact that some of the older library content leaves a bit to be desired, but to release these new drum kits in 2018 to "Service Select" is a bit embarrassing. Vectorworks is professional software and deserves professional-level libraries (which in other cases it succeeds at).
Sorry 😄
I think the challenge here is that resources need to be good for more than visualization. My primary use of this type of symbol would be for confirming spacing (I once had to investigate if we had made a riser big enough for this famous Canadian drummer - link). At first glance I would say none of the stands in these drum kits would actually stand up. When I look at the Pearl and Mair website all of the stands are setup with their legs fully extended. For me the outside footprint (in this case the legs) has to be accurate or its not really worth modelling something like this.
Kevin
You are right that the placement is easy to adjust by moving around individual symbols 🙂
That being said... the individual elements aren't even right. Placement aside, give us cymbals on accurately-sized stands, a floor tom that's the correct proportions, mid and high toms that are the correct proportions and that attach to the top of the kick drum, a kick drum that's the right proportions, a snare drum that are the right proportions, etc.
So first we need to start out with better symbols. In all honesty, these look like someone just 'guessed'.
Now back to layout... I looked on Pearl and Mair drum websites and didn't see the layouts mentioned above, but I have have missed them. Maybe I'm crazy, but in 15 years as a percussionist I've never seen a set-up that resembles any of those included in the new library. For what it's worth, most kits start with the same layout of kick, snare, hi-hat, 2-3 toms, and a cymbal or two, which then gets added to as the number of pieces grows. But that baseline set-up isn't anywhere to be found in this library. In fact most of the included layouts aren't even playable (looking particularly at the snare and hi-hat relationship, for example). And there are weird attachment methods in some of the set-ups that don't exist in real life. So while I'm not suggesting that the library include every possible layout, the ones it includes should at least be somewhat realistic.
I truly don't mean to be rude; I just don't understand how we end up these weird toy-looking things in what should be a professional, usable library of a common thing. 😕
Edit: Adding an image of that basic set-up mentioned above. 95% of drum kits look like this, or start as this and then get additional toms and cymbals:
If this is somewhere to be found in the new library and I missed it, my apologies. Or if there are other drummers on here that can point out that what I've written is way off base, that would welcome as well. 🙂
Edited by Andy Broomell
Just for fun I thought I would post some screen shots of the symbols (and cymbals for that matter) I've made for this purpose.  All 3D elements are pretty simple.  All circles are 12 sided polys, and hardware are all 4 sided polys which minimizes render times significantly.  All are accurately sized.  The finish on the standard kits is a white fade and it is set up so that I can edit the 3D component and select any shell which will select all of them in a group, change the color in the attributes menu and you can immediately change the color of the entire kit.  These are the things I do when I need a break from real work....
Edited by scottmoore
  • Like 3
These are fantastic Scott. In a video I linked to about C4D recently (link here) the speaker talked about how important personal projects were to a designer's sanity. Sounds like you use them in the same way. Your work is very inspirational to see!
Its sort of what this wishlist item was all about -
I agree with Evan that your kits definitely have market value. Good for both rendering and for working drawing use.
I'd also be curious to learn a little more about your texturing approach.
Thanks for sharing!
Kevin
1 hour ago, Rob Books said:
Our area is not big enough to have storage for all the things we model.  not to mention, that sometimes it is weeks or months before we get freed up to work on a particular library, or we work on it as a change from working on something else so it is over months to get it all together.  it is easier to work off the cut sheets as those can be stored on a computer.  We also expect that the manufacturer would have accurate drawings of their products.
All very reasonable. From an outsider perspective it feels like there's a lot of pressure on your department and a never ending wishlist, especially after the creation of Service Select. I try to see modelling each new object as a challenge to use the VW tools in a new way. Modelling objects needs to be fun or I think I would do something else. That's partly why I suggested referencing physical objects as it gets you away from a computer for a bit. Maybe you do need to rent a drum kit 😊 for workplace stress relief.
Kevin
  • 3 weeks later...
