creating a pillow
How about subtracting solids?
1. Extrude a rectangle to the overall size of the pillow (or a little larger), the thickness is probably the mose important.
2. Use the polyline tool to create a concave shape that is larger than the rectangle. This will be the curve to care off one side of the rectangle.
3. Either copy/rotate or create new shapes for the other three edges.
4. Select all 5 objects and subtract solids.
Or Intersect Solids?
1. Create and elipse and extrude it.
2. Look at a side view of the extrusion and screate another elipse. Extude that.
3. Select both extrusions and Intersect Solids.
It all depends on how accurate you need the pillow to be.
Don't ask how to put on fringed tassels. ;-)
Pat
If you start with
Model>3D PowerPack> Create Interpolated Surface
you can make a flat surface and pull the verticies up and down to make the surface bulge you will get (say) the top half.
Then mirror it to get the bottom half and push it around.
This produces a fairly realistic pillow form
Edited by propstuff
And just to prove I have no life..........
Here's a more finished one, ...complete with tassells. :-D
Top:
Push and pull verticies to get the top half
Extract edges to get the seam line, Ungroup and Compose to make 1 NURBS Curve (keep somewhere)
Bottom:
Use Curve to make new Nurbs surface
Push and pull new surface to make bottom half
Move Bottom down a small amount to make room for braid
Braid:
Get Curve back again
Duplicate curve and move it down the same distance as the bottom was moved
Duplicate it again amd move it half way between them
Scale the middle one to make it a bit bigger than the other 2
Loft between the 3 curves.
Tassel:
Draw half profile of body
Sweep
Draw curvy line. Extrude along Path with a circle to make 1 string
Make symbol of string
Place multiple string symbols and group
Place Tassel body in place with string group Create Tassel symbol
Place Tassel Symbols in place
Render
Weight with Textures 1.5MB
Weight without Textures 650KB
cheers
  • 16 years later...
10 hours ago, ashot said:
@propstuff can you please attach a VW sample file the final pillow product with Tassel & texture
Sorry, that was 16 years ago. The file is lost to time....
The Forum also seems to have lost the image files that were attached.
I have barely touched SubDiv, so I'm not sure, but that may well be an effective way to go these days.
N.
  • 2 weeks later...
HI Guys,
I have been modelling in this area recently.  There is a difference between modelling pillows and cushions.  Although they are right up Subdivisions alley, NURBS have a lot of control in this area.  The sofa below has both, cushions and pillows.  If you notice the cushsions have a subdivision top surface, rounded corners and flat bottom.  The pillows are the type sound in any home.  All done with NURBS.  The pillows can have a different radius on all sides, top and bottom,  curves and isoparms could be extracted to decorate them if required.
The sofa consists of 16 bands interwoven between the spokes.
Rendered/Animated in Vectorworks for a change.  Does a pretty good job.
Edited by VIRTUALENVIRONS
