Damon Design Posted August 24, 2007 Share Posted August 24, 2007 Can someone please tell me how to find and select to edit the Viewport Crop when I have assigned it a 0 line weight? When in the edit mode there is nothing to select-even >select all will not find the geometry of it. Thanks Quote Link to comment
P Retondo Posted August 24, 2007 Share Posted August 24, 2007 Tad, try Select All ( again. It always works, unless you don't have a viewport crop object at all. That's always possible. To double check that, draw a rectangle and close the edit - if there is more than one crop object VW will warn you. Quote Link to comment
Ray Libby Posted August 24, 2007 Share Posted August 24, 2007 Your crop object is in a class that is not visible. Turn on all classes and you will be able to select it. A good rule of thumb is to always make the class of crops "none". Quote Link to comment
Damon Design Posted August 24, 2007 Author Share Posted August 24, 2007 Yeah actually doesn't have a crop- DUH! Automatically is resizing per the new data. Also was having an issue with Section Viewport Crops but figured out defining the section parameters was the way to go there. Anyhoo thanks for the quick response Cheers Quote Link to comment
