Marcelo Posted April 3, 2000 Share Posted April 3, 2000 Is it possible to print to a large format printer from VW? We are trying to print a file from the windows version to a networked Encad NovaJet 4 and have had absolutely no luck. All we have been able to do is lock up the program in numerous attempts. VW in general is a great program but it seems to have some serious printing shortcomings. Quote Link to comment
Guest Posted April 4, 2000 Share Posted April 4, 2000 This may be either a network or print driver issue. VectorWorks uses the operating system to print to. Then, your operating system tells the print driver what to print, then the print driver tells the printer. There are no drivers built into our program. If you can print from your operating system, you should be able to print from VectorWorks. Please check for the latest driver for the NovaJet as well as your network settings. Also, try setting your virtual memory manually if you have 3D objects in your drawing. This might help as well. If you are still unsuccessful, please contact Technical Support at (410)-290-5114 for further assistance. ------------------ Brian O Diehl Graphsoft, Inc. Technical Support Quote Link to comment
