Wall Styles
walls styles are basically walls that have a name rather then not.
they both can have components
the styles walls show up in the drop down menu
they NNA walls are stored in the Libraries Folder
custom walls are stored in the document (unless copied to the default mcd drawing in the library)
  • 2 weeks later...
I think the best part of the wall styles system is being able to swap out different walls that have different components/thicknesses and anchoring a particular side or part of the wall to be fixed. This is great when you decide you want a brick wall or 2x6 wall but need the extra thickness to be offset to the interior.
Anyways, create the dashed with classes rather than embedding that in the wall style. That works.
Edited by dcont
