mikatoa Posted August 3, 2007 Share Posted August 3, 2007 Hi The way we draw in this office is by having the working file and the print file separate. Every time I open the print file this error occurs...[Note the update ref is set to Automatically during opening...] 'An error occurred while converting a Text Link using the Format named "Door Record" (probably out of memory). The Text Link has been deleted from the document.' To work around this I need to delete the ref symbol and then update the work group ref.when file is open. Any suggestions. Quote Link to comment
cbaarch Posted August 5, 2007 Share Posted August 5, 2007 I assume that you are not using sheets and VPs with this method there is really no need to create a separate print file Quote Link to comment
mikatoa Posted August 6, 2007 Author Share Posted August 6, 2007 cbaarch..thanks for the input but we moving off topic. Just need someone who can sort the error out. Just to let you know our sheet layers with VPs and title blocks are located in the (1) print file. The working files are (separate) drawing files with plans, section, elevation etc etc etc... Quote Link to comment
Guest Posted August 6, 2007 Share Posted August 6, 2007 Send the file(s) to tech support at tech@nemetschek.net Quote Link to comment
mikatoa Posted August 16, 2007 Author Share Posted August 16, 2007 Katie, Any ideas what the turnaround reply is. Emailed 07/08/07 Quote Link to comment
mikatoa Posted August 21, 2007 Author Share Posted August 21, 2007 Drake from tech support was very helpful. He noticed my symbol definitions having different records attached to them. Thanks Heaps Drake. SOLUTION 1: In edit (stubborn) symbol (without selecting any text or lines) check which records are X in the OIP. De-select any unrelated records. If it doesn't work see Solution 2. SOLUTION 2: Email tech support. Quote Link to comment
