tmichealsmith
Printing to register tape w/ VW
I was wondering if anyone has any knowledge of printing to a register tape from vectorworks. is it as simple as making a sheet as long and narrow as the tape?
4 answers to this question
I know where you're going with this.
Do You have a reg tape printer that will hook up to a computer ?
I'd love to try it.
I do not have a printer yet, though I am in the process of trying to acquire one to experiment with. If this works it can speed up, and increase the accuracy and efficiency of installing of lighting rigs by quite a bit.
Here's an idea to try:
Using a plotter > divide the paper width into 2" +/- segments> format the strips > VW Sheet ( segments can contain same or different info )>set the segment lengths via custom page set-up to anything less than the length of plotter roll ; )
The plotter will churn out the page until it runs out of paper to plot on.
Finally, chop-cut the roll at the segmentations using a standard paper cutter.
Taking Islandmon's idea a bit further, just buy plotter paper in a narrow width. I know our paper supplier will slit a roll to any width we specify. Then just print on a roll-capable printer. (Epson's 2200 comes to mind as an inexpensive but reliable option)
Good luck,
