Diana Posted July 23, 2007 Share Posted July 23, 2007 I have been exporting dwgs from VectorsWorks 8.5 with no problem. I am now on VW10 for Mac. I can export but when I open it up in AutoCad (and re-exporting to VW) all the text is missing! Is something set wrong? --Diana Quote Link to comment
Guest Posted July 23, 2007 Share Posted July 23, 2007 See if you can marquee select around the text and check the Attributes palette. The text may be set to the same color as the background. The other thing to check is the text size. Sometimes the text size reverts to 0, which would be invisible on the screen. Quote Link to comment
Diana Posted July 23, 2007 Author Share Posted July 23, 2007 Thanks for your quick reply. When I export it, there is text of all different sizes, some in groups, some in callouts, some with white backgrounds, some with no backgrounds, some loose. None of it shows up at all. When I reimport there is simply nothing there to select. Now I export to VW8, put it over on our old G3 and export from there, then transfer it back to the Server and new Macs to email out! The text comes in as Geneva, even though it was Helvetica originally. Quote Link to comment
Guest Posted July 23, 2007 Share Posted July 23, 2007 Diana, Send the VW file over along with a description of the problem to tech@nemetschek.net Quote Link to comment
islandmon Posted July 24, 2007 Share Posted July 24, 2007 Recall that dxf/dwg exports at World scale not Page scale and that most Acad Users seem to prefer Black background with magenta & white colors. Therefore, depending on your import Page scale ... text imports at very small point sizes and often as white on your white VW background. Use VW>Display Prefs > Black background to help find those little suckers. Quote Link to comment
