ErichR Posted July 19, 2007 Share Posted July 19, 2007 These are the instructions in VW Help: Cutting 3D Sections The Cut 3D Section command cuts a 3D section, or slice, through a 3D model while leaving the model intact. The slice is placed on a new design layer. To cut a 3D section from a 3D model: 1.Select the 3D model to section. 2.Select Model > Cut 3D Section. The cursor changes to cross-hairs. 3.Click to set the start of the section. In my Model Menu there is no Cut 3D Section command. This makes it difficult to execute. VWA 12.5.2 WXP Quote Link to comment
mike m oz Posted July 19, 2007 Share Posted July 19, 2007 You need to add it to your Workspace using Workspace Edit. You should add Cut 2D Section as well whilst you are doing it. Quote Link to comment
