kellhammer Posted June 29, 2007 Share Posted June 29, 2007 If I draw a floor plan on the wrong layer, what is the easiest way to put it on the desired layer. Copy/paste doesn't seem to work Quote Link to comment
Gerrit Posted June 29, 2007 Share Posted June 29, 2007 Paste in Place ? Or use the OIP popup layer list. Eventually uncheck/check the "Wall Height connected to the layer Z value". Quote Link to comment
kellhammer Posted June 29, 2007 Author Share Posted June 29, 2007 Gerrit Could you elaborate? I'm new to VW and so far I really think it could really improve my practice. Is OIP the "object layer palette"? Quote Link to comment
Ray Libby Posted June 29, 2007 Share Posted June 29, 2007 Object Info Palette. Window menu > Palettes > Object Info Quote Link to comment
dcont Posted June 29, 2007 Share Posted June 29, 2007 (edited) Be sure to select all and then in the object info palette, select the layer to put it on from the pull down list. Otherwise, I typically select the objects, use cut, navigate to the correct layer and paste in place Edited June 29, 2007 by dcont Quote Link to comment
kellhammer Posted June 29, 2007 Author Share Posted June 29, 2007 I guess I should describe what I am doing I imported a PDF floor plan to a layer I created to have it reside in. Then I traced over the PDF plan with my selected wall types. I forgot to change the active layer to the apprpriate model floor plan and drew it on the layer I created for the PDF floor plan to reside on. Now I try to cut and paste the only VW walls and move them to my desired mod floor plan worksheet. When I do this it shows up as a elevation of the floor plan. Why? Quote Link to comment
Gerrit Posted June 29, 2007 Share Posted June 29, 2007 Sounds like your target layer is in an elevation view. Check the View Menu > Standard Views, and switch to Top/Plan. Quote Link to comment
kellhammer Posted June 29, 2007 Author Share Posted June 29, 2007 That got it!. Fixed thank you Quote Link to comment
dcont Posted June 29, 2007 Share Posted June 29, 2007 Also keep in mind that individual design layers can be in different views, such as plan, top plan, elevation, isometric or perspective. to force all visible layers to a certain view, try using stack layers under the view menu. or change the standard view on while each layer is active. Quote Link to comment
