I have recently had VW12.5 Fund. installed onmy machine at work and I'm having some trouble printing.
Every time I set the printer in the page setup it sets my printer scaling to 50% (not the vectorworks scaling, this is the print driver scaling).
This is irritating, but not a problem for most of the printers that allow me to change the scaling back
However for our 2 main plotters, a TDS400 and TCS400, the scaling option makes no difference to my Vectorworks pagesetup, it shows at 100%, and I don't have access to all of the plotter properties as they are networked.
When you select the TDS400 and A1 paper (landscape), it tells me that the paper size is 1682x1188mm, twice that of an A1 sheet, If you then set your page size to proper A1 dimensions, it says under pages that both the horizontal and vertical values are 0.5!
It looks very much like VW's is changing the scaling in the TDS plotters too, only with no way of me changing it back again.
I have checked the scaling in my Windows printer preferences, and all printers are set to 100% scaling.
I have played around with all scaling options possible in both vectorworks and the printer drivers and none of them make a difference...
Alex W
needless to say this is very frustrating
6 answers to this question
