Gabrio 0 Posted March 4, 2000 a problem, when I try to open a big VW 8.5 file (7 MB) I've the caution message below -39 End of File reached during read attempt to read file -FSREAD then it's opened a recover copy of file missing of all the layer (only one, instead of 8) what it's happened? thank you ------------------ Gabrio Rossi an italian architecture student Quote Share this post Link to post
Guest Posted March 8, 2000 A negative 39 error message, usually means that the file is corrupt. When this happens the file will open with as much data as possible, sometimes it's a line and others it could be a bunch of objects. What you are seeing in the one layer is all of the data the program could retrieve from the document. If you have a back-up document use that to get the other information lost. Quote Share this post Link to post
