td4stage Posted June 20, 2007 Share Posted June 20, 2007 Hello All, I have a nice image of a piece of marble that I'd like to use (jpg, 150dpi, 600x600pixels). I create a texture, filtered image, and apply it to an extrude with fill set to solid. The extrude is textured, but with hundreds of tiny squares of my image texture. If I resize it up, then it just makes bigger squares and loses some of the detail. Is there a way to setup an image that makes a better texture? Any suggestions are welcome! Thanks, Quote Link to comment
Guest Posted June 20, 2007 Share Posted June 20, 2007 When creating the texture, you can assign the size of the texture. That may help a little bit. Quote Link to comment
Ray Libby Posted June 20, 2007 Share Posted June 20, 2007 If I understand the problem, you need to create a seamless texture. Photoshop has a filter that will do it. There are some free applications and info here. http://www.google.com/search?q=seamless+texture&rls=com.microsoft:*&ie=UTF-8&oe=UTF-8&startIndex=&startPage=1 Quote Link to comment
