The Hamma
DRAWING LABEL RENUMBERING
Often we have details that we pull in from other projects and or we rearrange the details on the sheet. Hence the need to renumber each label in consecutive order. It would be great to have a tool that I could set to a start number and click every consecutive detail mark and renumber them sequentially without having to edit the Object info for each item. This would save a great deal of time and my hands from carpel tunnel syndrome.
P.S. it would be great if this worked on door and window marks, detail marks, and any other object that has record based number field.
Edited by The Hamma
1 answer to this question
There is a 'Number Stamp Tool " ... does what you require except for the Record Fields stuff.
Also you can set-up consecutive VP Templates with pre-numbered boxes to accept the links to details.
