Tamsin Slatter
Gradient Problems with Gradient Settings
If I create a gradient and use it to fill a shape, then use the Gradient Settings palette to change the appearance of that gradient all is well
HOWEVER, if I then create a SECOND gradient, it appears in the resource browser, I can use it as a fill as usual. But if I try to amend it to be radial etc via the Gradient Settings palette, the second gradient doesn't appear. I can only use my first gradient or the default content.
Any ideas?
Choose the attribute mapping tool and ensure the gradient path is long enough and centered appropriately around the filled object.
You don't have to - you can adjust the length and position of the gradient in the Attribute palette when you click on the edit button.
The Attribute mapping tool is a little easier to use though.
