Melshimber Posted June 13, 2007 Share Posted June 13, 2007 Hiya We are trying to import images of a real tree into Vectorworks using the import function. I thought that we used to just import the image and the white background would go transparent to allow you to see through to the elevation behind. It doesn't seem to anymore (or my memory is faulty!) Does anyone know of a way to do this. Using layer transparencies does not work as the white box is still visible even when transparent. ttfn Mike Quote Link to comment
Guest Posted June 13, 2007 Share Posted June 13, 2007 You'll want to create an image prop of the image. Do you have RenderWorks? Quote Link to comment
Dexie Posted June 13, 2007 Share Posted June 13, 2007 If you import the image file and choose no fill from the Attributes Palette this should turn anything that is white in the image to transparent. Quote Link to comment
