Bob Wagner
Triangulation Again
Does anyone have in their collection of code an algorithm to triangulate a 3D polygon. In version 10.5, I did this by Converting to Nurbs then converting to 3Dpolys. This doesn't work in 12.5, not unless you choose each nurb surface and set its U and V value to 2. This I haven't worked out how to do in a plugin. At the moment I export as 3DS and re-import the 3Ds file. This might be ok for now but not what I really want.
Why do this you ask? Well I have my unfolding working pretty well, but it all requires a model to be triangulated.
//calculate the number of vertexia & faces in symmetry triangle
//This is based on the class type
//First the polyhedron face...
for(i=1; i<=frequency; i++){
if(i == 1)
vertex = 3;
else
vertex += (i + 1);
faces = frequency * frequency;
edges = (vertex + faces) - 1;
{ frequency is the number of edge subdivisions of the triangle }
Thanks for this. However I already an cope with this, the problem is actually dividing the big polygon into the individual triangles.
Number of sides -2, is how many triangles minimum needed. however you have to check for turns left and right and check it the triangle actually formed is in the original polygon etc.
Bob
