Mitchell Posted June 13, 2007 Share Posted June 13, 2007 I am currently experiancing difficulty in moving a viewport using the intersection of grid lines within the viewport. My intial diagnosis is that vectorworks is unable to snap to dashed lines located within viewports of 'large' projects containing workgroup references. I am assuming it is a graphics card-vectorworks issue. Interestingly I can snap to them when annotating - just not when the basic sheet layer view. I drew just two lines and workgroup referenced them into a blank document and could snap and move from all points which makes me think its struggling with complexity of the project. All layers, classes, view options, viewport settings (both in drawing and workgroup reference) are set to 'ON' or 'SHOW/SNAP/MODIFY ALL' Anyone experianced similar or same issues or able to offer a solution? Quote Link to comment
Dieter @ DWorks Posted June 13, 2007 Share Posted June 13, 2007 you can't snap to lines that are in a vp, you can snap to points! i use loci if i must have a certain point. Quote Link to comment
islandmon Posted June 13, 2007 Share Posted June 13, 2007 A VP Sheet Container is always 1:1 scale ... whereas... VP Annotation = scale set by the OIP... therefore all the VP Layers are snappable via Annotation & Crop. Quote Link to comment
Mitchell Posted June 14, 2007 Author Share Posted June 14, 2007 Thanks for the helpful reply. Loci placed in the workgroup referenced file does the job. Quote Link to comment
P Retondo Posted June 14, 2007 Share Posted June 14, 2007 The problem is that those loci (even if they are locked!) are going to disappear if changes are made in the contributor WGR file. Then VW completely rewrites the WGR layers. To get your loci to stick, you will need to create a layer link to the WRG layer in another layer resident in the container file, put the loci there, and use that layer containing the link in the VP. Quote Link to comment
