Matty Posted June 12, 2007 Share Posted June 12, 2007 I am fairly new to VW and only currently work in 2d, however prior to VW I worked with autocad which had the ability to select a line and then select any number of lines which you wish to extend to it without having to repeatedly select the first line, is the same function available in VW? Quote Link to comment
Christiaan Posted June 12, 2007 Share Posted June 12, 2007 You could try this one, from the Help files (searched for "connect multiple lines") To connect multiple selected objects to a boundary object: 1.Select the objects. 2.Click the Connect/Combine tool from the Basic palette, and select Single Object Connect from the Mode bar. Press and hold Alt (Windows) or Option (Macintosh) to allow multiple selection. 3.Click on one of the objects to connect, and then click on the boundary object. The selected objects are resized to join the boundary object. Quote Link to comment
