jeffroyer Posted June 8, 2007 Share Posted June 8, 2007 How does one go about ensuring that layers referenced in with wgr are accurately aligned to the layers in the primary document? Quote Link to comment
P Retondo Posted June 8, 2007 Share Posted June 8, 2007 Jeff, not quite sure I understand your question. (0,0,0) will be the same in both files. Quote Link to comment
islandmon Posted June 8, 2007 Share Posted June 8, 2007 However, if you choose to offset the origin in File-B and then WGR into File-A which has the origin at the Drawing Center 000, then just as Pete indicates the Layer origins align to 000( Drawing center )... but if you had set-up of the File-B plans to use an offset origin ... then they will be out of alignment by the XY of the offset in File-A. Quote Link to comment
jeffroyer Posted June 8, 2007 Author Share Posted June 8, 2007 That's precisely the issue. Dealing with drawings from multiple consultants and multiple formats (anyone ever work with Softplan?). I think I have a better handle on how to get this done though. The main issue is the lack of a consistent common point to lock into the 0,0,0 point. thanks for the input Quote Link to comment
islandmon Posted June 9, 2007 Share Posted June 9, 2007 Alignment of DXF/DWG imports requires the location and realignments of all the various coordinate centers ( usually lower left corner for ACAD ). Quote Link to comment
cbaarch Posted June 10, 2007 Share Posted June 10, 2007 you create a layer link for the workgroup referenced layers that you bring in in 12.5.1 there is a query if you want to LL when you firt create the WGR at the bottom of the dialog box then you can locate/rotate/flip the layer link which will get updated when wgr is updated. Quote Link to comment
cbaarch Posted June 10, 2007 Share Posted June 10, 2007 forgot to mention you have to unlock you LL first to move it. Quote Link to comment
