Accurately aligning referenced layers
However, if you choose to offset the origin in File-B and then WGR into File-A which has the origin at the Drawing Center 000, then just as Pete indicates the Layer origins align to 000( Drawing center )...
but if you had set-up of the File-B plans to use an offset origin ... then they will be out of alignment by the XY of the offset in File-A.
That's precisely the issue. Dealing with drawings from multiple consultants and multiple formats (anyone ever work with Softplan?). I think I have a better handle on how to get this done though. The main issue is the lack of a consistent common point to lock into the 0,0,0 point.
thanks for the input
you create a layer link for the workgroup referenced layers that you bring in
in 12.5.1
there is a query if you want to LL when you firt create the WGR
at the bottom of the dialog box
then you can locate/rotate/flip the layer link
which will get updated when wgr is updated.
