Viewport Layers
Which "Pull Down" is your grid layer appearing on top in? Does the grid layer appear on top when looking at the design layers?
Are the "shaded boxes" on a design layer?
If you are looking at the Navigation Palette, check that the grid layer has a "1" in the right column - this palette can be sorted by visibility, name or number, the number indicates which layer is actually "on top".
