javito Posted May 30, 2007 Share Posted May 30, 2007 Hello, I am triying to build complex polygons with a lot of vertex from a os map. If I select all the lines and compose them it didnt close the polygon because there are double points very close. It is possible to specify a threshold distance where those points are merged into one? It not, Any ideas how to do it in a easy way? Many thanks Quote Link to comment
Guest Posted May 30, 2007 Share Posted May 30, 2007 You can use the 2D reshape tool to delete the extra point Quote Link to comment
javito Posted June 6, 2007 Author Share Posted June 6, 2007 Thanks, but what can I so when there is a lot of lines and this operation cant be manually, autocad has a tresshold parameter that merge points closer than an specific distance, is there anything like this in vectorworks? thanks Quote Link to comment
mike m oz Posted June 6, 2007 Share Posted June 6, 2007 Optimise Drawing from Vectorbits has an option to Simplify Polygons: http://www.vectorbits.com/ Quote Link to comment
islandmon Posted June 6, 2007 Share Posted June 6, 2007 Let us not forget the power of Zoom Quote Link to comment
mike m oz Posted June 6, 2007 Share Posted June 6, 2007 There is a VW 8.5 plug-in to simplify Polygons in the old Plug-ins section at Vectordepot. (May or may not work in later versions - try it and find out.): http://www.vectordepot.com/Plugins1.shtml Simplify Polys Removes vertices from polys to simplify their appearance. User definable parameters to control results Contributor: John Williams Version: VW 8.5 Quote Link to comment
russh Posted June 6, 2007 Share Posted June 6, 2007 (edited) I think that what Javito means is that he currently has a collection of lines which he needs to convert to a polygon or polygons. The problem is that the endpoints of some of these lines are not coincident - there are gaps between the lines. AutoCAD has a "fudge factor", a user defined tolerance, which overcomes this. I don't think VW can do this, unless someone knows how to get around the problem. Edit: just noticed the other thread on this. Mike is right: Chainmaker will do what you need. Edited June 6, 2007 by russh Quote Link to comment
