Bruce Kieffer Posted February 18, 2000 Share Posted February 18, 2000 I believe that the angle dimension tool is broken in version 8.5.1 for the Mac. I can place an angle dimension, but I can no longer grab the dimension text and move it in or out to shrink or grow the witness lines. This worked in previous versions. Now all that happens is I can move the text side to side. Could someone please confirm this problem? Quote Link to comment
Marc Pitman Posted February 18, 2000 Share Posted February 18, 2000 Try grabbing the witness line on either side of the text. You should be able to move it, the witness line, in or out as you used to. If you grab the text it, the text, can only be moved along the witness line. Quote Link to comment
Bruce Kieffer Posted February 18, 2000 Author Share Posted February 18, 2000 Thanks. That way it works fine. Quote Link to comment
