DTM/Surveyfileimport
Juan
I have some problems with the SurveyFileImport, never work and always show me a Script Error: Line #56: datafile name: Text; {error:Expected name of a variable type.} etc..When I check this script in Create Plug In option, I found the same script like the old macro in MiniCad7. How can I fix this problem?..Thank you
I think I have seen this before. Check the type definition, The Text type is obsolete, it has been replaced by String type. Just change the declaration and it should work.
[This message has been edited by klinzey (edited 02-14-2000).]
Thank you Klinzey, the problem was fixed with your useful recomendations: GO TO CREATEPLUG-IN, search SurveyFileImport, click Script
and change in Procedure:
Procedure
MyReadLn(dataFileName:STRING...)
and change in Variable:
VAR
DataFileName:STRING...)
The Text Type is obsolete
THANK YOU SO MUCH
J U A N
