Kphips Posted May 10, 2007 Share Posted May 10, 2007 Hello I am currently new to using Vectorworks and our school has Version 10. I followed through the book until it came to the part with walls. I followed the instructions and drew the walls and did the roof command. After that i would switch my view to Right Iso and all it shows is a 3d roof but no walls. They do not raise of the ground. I've looked at all the options and tried many things but nothing happens. Can anyone help me? Kahle Quote Link to comment
Guest Posted May 10, 2007 Share Posted May 10, 2007 Switching views only applies to the current layer. To look at the walls with the roof, you'll want to create a new layer, then create a layer link on that layer including the walls and roof layers. Quote Link to comment
Jershaun Posted May 11, 2007 Share Posted May 11, 2007 Also check if you walls have height. Shaun Quote Link to comment
Kphips Posted May 11, 2007 Author Share Posted May 11, 2007 Okay I found out that the walls didn't have a height. Is there a way to set it so walls have a set height instead of 0 Quote Link to comment
Guest Posted May 11, 2007 Share Posted May 11, 2007 If the wall is a styled wall, you'll have to edit the wall OR remove the checkmark next to "Height linked to layer" in the OIP. If it is not a styled wall, make sure the checkmark is removed. Enter the height next to the deltal z value Quote Link to comment
P Retondo Posted May 11, 2007 Share Posted May 11, 2007 To set the default height for walls you create, set the layer Z+/- to some value other than 0. Quote Link to comment
Guest Posted May 11, 2007 Share Posted May 11, 2007 Ignore my last post - I just noticed you are using VW 10. That would make no sense to you. Instead - set the wall height in the OIP next to Delta Z or wall height - I don't recall the exact field name. I would still focus on the layer link concept - you'll need that if the roof is on a separate layer than the floors to view the whole model. Quote Link to comment
