P Retondo Posted May 9, 2007 Share Posted May 9, 2007 I can't get a texture bed to display a texture. It always displays as a wireframe only: Has anyone had success using the texture bed site modifier? Quote Link to comment
propstuff at MJLA Posted May 9, 2007 Share Posted May 9, 2007 I'm doing a DTM at the moment Pete, and I can't get them to texture either as None class or as a unique class with it's own class texture. A 3D poly after Send to Surface will show. seems like a Bug N. Quote Link to comment
P Retondo Posted May 9, 2007 Author Share Posted May 9, 2007 Nicholas, thanks, I'll submit a bug report. Quote Link to comment
P Retondo Posted May 14, 2007 Author Share Posted May 14, 2007 Problem solved by Gunther at NNA! There are two fields in the OIP where the texture bed class has to be entered - the normal field with a drop-down menu at the top, and a second field more towards the middle of the dialog box, where you have to type in the class name. Once you do this the texture bed rendering will be displayed. I've asked Gunther if the code can be changed so that it would be unnecessary to enter the class two times. Quote Link to comment
