Abacus Posted May 9, 2007 Share Posted May 9, 2007 After upgrading to 12.5.1 from 12.0.1, wall (header) lines of doors do not take on the "Ceiling-Main" attributes except for visibility settings. In old files opened with 12.5.1 show the wall lines correctly until a change is made to the door. I assume there is a setting I am unaware of and hope someone can help me out. My temporary and maybe permanent fix was to replace the 12.5.1 "Door.vso" with the 12.0.1 "Door-vso". Quote Link to comment
dcont Posted May 9, 2007 Share Posted May 9, 2007 I think if you change the attribute of the ceiling main class, it will take on those attributes. Quote Link to comment
Abacus Posted May 9, 2007 Author Share Posted May 9, 2007 dcont, That is the problem. The door wall lines do not change regardless of the changes I make to Ceiling-Main attributes. "Use at Creation" is checked. I use a dashed line for Ceiling-Main but the door wall line shows solid. This was not the case in 12.0.1. Thanks Quote Link to comment
dcont Posted May 9, 2007 Share Posted May 9, 2007 With the door selected set the attribute to not be class style for the pen and line style. Then adjust the line attributes by parts in the door setting view tab. Quote Link to comment
Abacus Posted May 9, 2007 Author Share Posted May 9, 2007 dcont, Thanks for your help! That works. I was sure I had already tried that along with every other possible combination of settings but obviously not. I so wanted to blame the program. Now I have shame :whistle: Thanks Quote Link to comment
