johncruet Posted May 1, 2007 Share Posted May 1, 2007 In VW 10 what i did was select "Style-Glazing 1" in a pulldown menu and the doors would render transparent in RenderWorks. In VW12, I don't see such a setting, and, despite the fact that I select Glass in the leaf type drop down menu, the door glass panels render solid. What do I have to do to get the doors to render transparent in the glass panels? This also is a problem in the side lights and the transoms. Quote Link to comment
johncruet Posted May 1, 2007 Author Share Posted May 1, 2007 OK, I was able to solve the door glazing by going to Settings>View>Special Classes>Ext. Panels>Style- Glazing 1. That solved the door, but then I did the same with the Side lights- Side Light Glazing>Style-Glazing 1 and I still get solid panels rendered. And I can't get the transoms to be transparent, either. Help! Quote Link to comment
dcont Posted May 1, 2007 Share Posted May 1, 2007 I think you have to set the Int. Panels as well. I guess the idea is to have an option to render the interior as a different texture than the exterior if needed. Quote Link to comment
jfmarch Posted May 1, 2007 Share Posted May 1, 2007 i think you need to check the info pallette setting for the sidelights. in particular look at the class settings for the glass, and make sure that class is visible and has the right texture in rendered view... Quote Link to comment
johncruet Posted May 3, 2007 Author Share Posted May 3, 2007 Did all of the above, and it worked! Thanks for your help. Quote Link to comment
