Speedy Gonzales Posted April 27, 2007 Share Posted April 27, 2007 This may sound like a dumb question, but is there a way to do this? I've created an array of lines from the center point of an arc and want to remove the section of lines from the center point of the arc and leave only those that extend beyond the arc. In AutoCAD, there is a "fence" command to trim the selected lines. I do know that I can first set up the trimmed lines to array, but there are many cases where I find a series of objects/lines that already exist and need to be trimmed. Thanks in advance for your thoughts and solutions. Quote Link to comment
eas Posted April 27, 2007 Share Posted April 27, 2007 There are two things to try. The clip tool draws a marquee that you can use to trim lines--but only orthogonally. If you use the clip surface tool you can trim any shape you can draw. In your example you would need a shape on top tf the lines that aligns with the arc. Select everything and choose clip surface. This is a tool find I use so often that I have a keyboard shortcut set up for it. Quote Link to comment
jeffroyer Posted April 27, 2007 Share Posted April 27, 2007 Take a look at this podcast by Jonathan Pickup: http://web.mac.com/jpickup1/iWeb/Site/Podcast/D14F12E0-3704-4974-8742-0973C00A7169.html I don't know if this method will work in your particular case but it is worth a try. Quote Link to comment
quigley Posted April 29, 2007 Share Posted April 29, 2007 (edited) Use the Connect/Combine tool not the trim tool - strange but true. Select the lines to the trimmed, choose the connect combine tool, first option, hold the ALT ket down and click from the endpoint of one line to the object you wish to trim to. Exactly same method as Jonathan's Podcast shows but you are trimming to the line/curve rather than extending to it. Edited April 29, 2007 by quigley Quote Link to comment
jan15 Posted April 29, 2007 Share Posted April 29, 2007 You could select the arc, then issue the Trim command (which cuts all those radial lines at the point where they intersect the arc), then optionally issue the Copy command (which gets the arc onto the clipboard), then use a selection box to select all the inner parts of the radial lines and delete them, and if necessary issue the Paste In Place command (which puts the arc back where it was). 4 to 6 clicks, depending on whether you decided to Copy the arc to the clipboard (so that you wouldn't lose it when selecting and deleting the radial lines inside it) and, if so, whether you had to paste it back in place afterward or were just as glad to be rid of it. Quote Link to comment
eas Posted May 1, 2007 Share Posted May 1, 2007 thanks for the command connect info--I am getting more familiar with this tool and it is clearly more useful than I would have anticipated. Quote Link to comment
Speedy Gonzales Posted May 9, 2007 Author Share Posted May 9, 2007 Thanks everyone for the assist. Along with discovering another method using duplicate area along an arc from a point after trimming the first line, it was gratifying to see that there is more than one way to skin a cat! Or trim a line. Quote Link to comment
