madgardenr522 Posted April 23, 2007 Share Posted April 23, 2007 I'm new to these forums and did a search first, but I didn't find anything on this question. I have a survey of a property that I have scanned for importing into a VW file (I'm using VW12.5.1 on a Windows XP Professional system) but just realized that the scale is 1" = 80' on the scanned plat. That scale doesn't show up on the standard engineering or metric scale options when you are designating a layer's scale. How do I create the scale I need for the scan layer? Thanks in advance, from someone who's a relative newbie at VW. Quote Link to comment
ionw Posted April 23, 2007 Share Posted April 23, 2007 In the layer scale dialog, near the bottom right, you will ss a number entry box. if you click in say 1" = 40'0" you will see it reads 480. Double that to 960 and enter that, and voila you have 1"=80'. also like almost every entry point in VW you can simply put after the value *2 (means times two) to get the value instead of doing the math manually. HTH, ion Quote Link to comment
madgardenr522 Posted April 24, 2007 Author Share Posted April 24, 2007 Thanks, that worked well! I appreciate your prompt reply. Quote Link to comment
islandmon Posted April 24, 2007 Share Posted April 24, 2007 This little fundamental scale feature... often overlooked ...provides tremendous platform adaptability. Quote Link to comment
