inserting text crashing VW
Post 77493 - everything seems to be in order.
I tried a blank document - same problem. If I only copy and paste part of the document at at time it will insert fine, if I try the whole page it crashes with this mseeage -
"VectorWorks has encountered a problem and needs to close...."
There shouldn't be a problem with this. I suspect there's either a bad character in the word document, something going on in the VW files, or some setting out of whack on the computer.
You are in a situation where almost all the computers are the same, the files are the same - so doing "testing" is challenging.
I didn't get the file, if you sent it.
