More Plant Tag questions
This helps with line weight etc. But is there a way to constrain the angle of the leader on the plant tag. Using the shift key, there is a class set up which is applied, the angle contraint setting is on in the constraints palette. The SmartCues don't seem to relate to the angle that results with the leader.
  • 4 weeks later...
The plant tag is a line with a few control points which you can move around by mousing over the control handle and dragging the mouse.
There should be a point where the shoulder meets the text & at the shoulder
my cursor only moves the tag and the cluster so I can't seem to move these lines connecting plants. Also, I don't see the symbol (+ with an arrow through it) that the training tape says I should use to move the tag around.
