greenmeadow Posted April 21, 2007 Share Posted April 21, 2007 Often when I am working on an old file that has been converted to VW12 the window or door or both tools are not selectable. Also the old windows and doors are "dead". How do I activate the door and window tools when they get into this state? Thanks Quote Link to comment
CipesDesign Posted April 21, 2007 Share Posted April 21, 2007 Try running: TOOLS>UTILITIES>UPDATE PLUG-IN OBJECTS. First, save a backup of your file, just in case... Usually the old PIO's will work fine once updated. Quote Link to comment
Jonathan Pickup Posted April 21, 2007 Share Posted April 21, 2007 i think there are two issues. The second issue is the one where the doors and windows are dead, and Peter is right, run the update command. The first issue is where you can?t choose the door or window too. This is usually when you have a class in the file called Door or Window. You are not allowed to have a class and an object with the same name. The solution is to rename the class called Door or Window (it only has to be a small change). Quote Link to comment
