talkietom
An easy way to do hedges
Hi, I draw free hand and curved hedges using the double line polygon tool clicking along an existing line and then use the plant line tool to give it texture. This can be very time consuming when 'tracing' round curved objects etc. Is there an easier way? I have tried using arcs and offsets and the converting to polygons but this doesn't seem to work.
draw with lines and arcs, then use the compose command to add them all together into on shape.
Or, draw them with lines and arc and then use the 2D ploygon tool with the paint pot mode flood the area...
Go to "Plant Definition", "Edit Plant Definition", "Render" check "Mass Overlapping Plants". Under"Default Prefs" "Size" "Spread" set this number to be oversized of what you set the "Spacing". This might take a little experimention, but VWL will automatically cut the circles and make the outline.
