shapefiles
No, that's no possible. The file needs to be centralized to import the file.
How often are the shape files you are using being updated?
I don't think I've seen shape files updated frequently - at least not enough to cause an outrageous amount of work.
i can not import shape files w/ just architect.
as to Katie's comment, it seems that is the way things should be. wether we are dealing w/ a shape file or a 3d oven for our BIM model why not use objects that are produced by others as if they were referenced symbols.
if i am doing a map and a road gets added to the original shape file all i need to do is click an update button and my VW map project is updated.
or
if a 3d oven model is updated by the company then my VW BIM gets updated.
