SUSAN1 Posted April 6, 2007 Share Posted April 6, 2007 I'M VERY NEW TO VW. I'M TRYING TO CREATE A PLANT LINE. THE MANUAL SAYS TO SELECT AEC, PLANTS, PLANT LINE. WHEN I SELECT AEC UNDER THE MODEL TAB, IT ONLY GIVES ME PILLAR, FLOOR AND ROOF OPTIONS, NOT PLANTS. WHERE AM I GOING WRONG? Quote Link to comment
Jonathan Pickup Posted April 6, 2007 Share Posted April 6, 2007 from the Menu Bar choose: Tool > Workspaces > Landmark this should change your workspace (the arrangement of the tools and commands) so that you are in the correct workspace... now draw an outline of the plant line that you want. don?t use lines for this, make sure that you use a rectangle or a ploygon. then, from the menu bar choose: AEC > Plants > Plant Line Quote Link to comment
SUSAN1 Posted April 8, 2007 Author Share Posted April 8, 2007 Thank you so much. It worked perfectly. Quote Link to comment
