gchianese Posted January 28, 2000 Share Posted January 28, 2000 I am having a problem with bitmap rendering since installing 8.5.1. When rendering a perspective with the rendering tool, the resulting view is not the area selected with the window. I only get a small number of objects rendered, and their size and location in the rendered image do not correspond to their that of the perspective view. Quote Link to comment
Guest Posted January 28, 2000 Share Posted January 28, 2000 When you are using the Render Bitmap tool make sure that you marquee the entire area of what you would like to have rendered. If you marquee a section of the drawing that is all you will see rendered. Quote Link to comment
gchianese Posted January 31, 2000 Author Share Posted January 31, 2000 Mark, I did surround the entire area I wanted rendered. We also tried the tool on another computer running a different copy of 8.5.1. We had the same results there. We also tried different files with the same result. The only version of 8.5.1 that doesnt have this problem is the Windows version. It seems like this is a bug in the mac version of 8.5.1. Quote Link to comment
Guest Posted February 3, 2000 Share Posted February 3, 2000 Do you think you can send me a file so I can test it out and see what can possibly be going on. Send the file to tech@diehlgraphsoft.com and include a phone number a brief explanation so I can follow what you are doing. Quote Link to comment
gchianese Posted February 11, 2000 Author Share Posted February 11, 2000 Mark, Try this, use the render bitmap tool with different pixel aspect ratio's. Youll find that only the 1:1 setting works properly, especially with larger files. The pixel ratio seems to act as a zoom factor within the selected window. George Quote Link to comment
Guest Posted February 16, 2000 Share Posted February 16, 2000 Try this, use the render bitmap tool with different pixel aspect ratio's. You'll find that only the 1:1 setting works properly, especially with larger files. The pixel ratio seems to act as a zoom factor within the selected window. The Bitmap render was made to work with the 1:1 screen pixel ratio. If it is not at 1:1 nothing will appear. You can change the DPI of the BITMAP by selecting the bitmap tool and then click the preference box in the mode bar, in here you can change the DPI to something higher. Quote Link to comment
